iR-c5180 out of focus on scanning direction.
  • BillAgudelo
    • Feb 2010
    • 84
    Hi, fellows,
    On this c5180 the image is out of focus on the scanning direction only.
    This happens even if I only copy in single color (K, M, C, Y).
    I have followed the indications dictated on bulletin TP03 174f.pdf to no avail:
    - Replaced ITB unit with one from a working machine.
    - Re-aligned the laser cam in all four laser units.
    - Performed COPIER>CLEAR>DC-CON and COPIER>CLEAR>MN-CON.
    - Replaced DC-Controller, Replaced System Controller, Replaced ribbon cable,
    - Last resort: Replaced Main Controller Box.
    - I even replaced the Pattern Reader Assembly.
    Note: All replacement parts came from a working machine.
    The DC-CON & MN-CON clear, and, the laser cam re-alignment were done again after replacing the circuits.
    I must be missing something.
    Please help!
  • teckat
    • 16083
    are u talking about Scanning off the Glass ????
    u stated>out of Focus on a single Color ??
    were u checking PG 5 single color prints ??
    explain single color ????
    The laser exposure system is controlled mainly by the DC controller PCB2(MAISY).
    Scanning direction- Main or Sub scan ?
    this pic is Sub-Scan--lead to trail edge-
    U first need to determine >
    if the image is out of focus on the ITB before transfer/separation to paper ??
    if the image is OK !!! on ITB/ and out of focus afte
    r
    transfer/separation
    Check your Secondary Transfer Roller unit
    if image is out of focus on ITB before transfer/separation - check ITB Drive Motor M1
