There is some text displaying at my IR6570
  • blu3sky
    • Jul 2010
    • 25
    [Misc] There is some text displaying at my IR6570
    the text is "The default key is corrupted or invalid", I think it may caused the fax button disappear. Please give me a solution?!?!?!
  • Borsody75
    • Mar 2011
    • 83
    You have to generate a new key.
    Go to Service Mode2 > Function > Clear > CA-key > OK
    Shut off the machine, then on.
    • ciaran
      • Mar 2011
      • 45
      here a solution for you
      ca_key.PDF
      • blu3sky
        • Jul 2010
        • 25
        thank you very much all
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5018
          Originally posted by Canon.Tech
          Out of interest what exactly is this "CA Key" ?
          Certificate authority key
          • teckat
            • 16083
            Yes, but what is it, what's it for !?
            Certificate - An electronic document that binds pieces of information together, such as a user's identity, duration of validity, the signature (typically signed by a CA), and a public key. It uniquely identifies individuals and servers. Certificates allow a client to authenticate the server prior to establishing a SSL session. A certificate contains all of the elements needed to send an encrypted message to the owner (using the public key) or to verify a message signed by the author of this certificate. Note that the private key is never transmitted or shared.
            Certifying Authority / Certificate Authority (CA) - A person or organization that creates certificates. Typically, digital certificates are signed by an independent and trusted third party to ensure their validity. The 'signer' of a certificate is known as a Certifying Authority or Certificate Authority (ex. VeriSign). SSL uses this third party CA to identify one end or both ends of the transactions.
            READ THIS>>>click on link below
