what should i do?
  • adhy
    • Feb 2011
    • 109
    what should i do?
    hi dear i need a help here, i facing an error 000fff-fff on my ir 5000. i hope some one could give me a solution. thanks for reply.
  • adhy
    • Feb 2011
    • 109
    hi thanks for your posting. but that is
    wont work.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Can you get into service mode, and give us the actual error code as listed there please.
      • adhy
        • Feb 2011
        • 109
        i was found the problem the DPC on service mode is "1" i change it to "0" and machine work properly.
        • mrfixit51
          • Oct 2008
          • 1975
          I am confused, I don't know what DPC(potential control) has to do with your error code???
          • adhy
            • Feb 2011
            • 109
            hi. the error history was cleared but i think is related to SSR pcb and Drum Heater pcb because of the Drum is not warm. i replace the two parts and set The DPC "1" the error was not occurs. by the way thanks for your post.
            • teckat
              • 16083
              Learn how to read your error codes
              click on pic to view>>>>
              • adhy
                • Feb 2011
                • 109
                [ATTACH=CONFIG]10522[/ATTACH]
                Good learning Teckat, i will back to the costumer soon to see the code error.
                • adhy
                  • Feb 2011
                  • 109
                  Re: what should i do?
                  Hi Teckat I am sorry too late to post this error History, but to day i going to the custumer's shop and see this error. i hope this pic solved the problem.
                  • mr.daus
                    • Apr 2011
                    • 98
                    hay friend,, are you chek some connector on board controller???
                    this code is malfunction on some connections
                    firdaus +(62)8195002007 firdaustrish@ymail.com
                    • adhy
                      • Feb 2011
                      • 109
                      hi to, the error has just solved after i replace the SSR pcb and Drum heater pcb and in condition DPC is 1 in service mode. i wondering why the code in alphabetical but not in numeric.
                      • gensys
                        • Jan 2011
                        • 323
                        What is it >>> 4., 4.1,?????????????????
                        Where is >>>1.,2.???????? or 3???????????????
                        If you have 1) - where 2) > ???
                        The Road will be Mastered by >>> the Going...
                        • Julianne
                          • mrfixit51
                            • Oct 2008
                            • 1975
                            If you read the string of messages, ADHY says that it is resolved...
                            • adhy
                              • Feb 2011
                              • 109
                              you can see the pic that i posted error 0061 was occurs between E fff, i thougt the error was related to the drum heater because after i replace the SSR pcb and the drum heater pcb the error were disappears.
