hi,i would say 80-90% solid black,but quite comparable to a working machine i tested the same.Text is also quite black on the drum in comparison to the faded text which comes out on the page.
Canon 2018 Faded
Sure looks like a transfer problem ..... but since you replaced the entire door assembly which all but eliminates that area as a problem...... I guess I'd try the HVT next.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
Welcome-glad your up and running again.---------BlazesigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
