Result Problem
  • andalasgt
    • Oct 2010
    • 49
    [Misc] Result Problem
    how to solve this result problem which has white lines printed on A4. Thanks a lot.
  • andalasgt
    • Oct 2010
    • 49
    Oh ya .. Machine is iR5000. Thanks
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1250
      Have you done a PM yet? Looks like coronas or dv unit. Rebuild the coronas and check out the dv unit - Toner coating on mag roller look even? And those white specks are probably damage to drum surface from arcing coronas.
      • andalasgt
        • Oct 2010
        • 49
        Thanks to blazebusiness. I have changed all coronas and polished Drum.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5000
          End??
          • dhanesh
            • Jun 2010
            • 63
            REplace corrona wires and clean ur drum
            DHANESH
            • andalasgt
              • Oct 2010
              • 49
              yes problem solved, thanks you very much,.
