Canon irc3100 error 70-3
  • DadO
    • Dec 2007
    • 403
    Machine have 160 K copies. After stabilizing and powering on for 2-3 mins and the final sequence start , machine throw error 70-3
    The time that passes
    after detection of the
    ITB home position to
    the next detection of
    the home position is
    shorter than a specific
    period of time.
    I found lines on ITB belt so i replaced it and replaced itb cleaning blade(blade only not whole assy) but no help still same error code is displayed.
    I searched SM so i could test the ITB belt sensor but could not found the procedure. Wouldnt this code show at start if sensor is bad since machine reach finall where u should get "ready" but insetad error 70-3?
    I found that on ITB assy i have two springs that make force on big mettal roller that aplly presshure on itb belt but when i remove the belt, the pressure is not equal on both sides.Could this be the problem?
    THX for any input!!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    period of time.
    THX for any input!!
    Read end enjoy
    ir3100c-022.pdf
    ir3100c-049.pdf
    • DadO
      • Dec 2007
      • 403
      Read and cry . Thx for input guys!
      • zoraldinho
        • Mar 2008
        • 5015
