ir7105 finisher V1
  • liffy
    • 15
    [Electrical] ir7105 finisher V1
    Will not use Tray2 ( lower tray) at all , Every job exits on Tray1 ( upper tray ). If staple selected , paper exits out of tray1, no error , no alarms. Even if Tray Destination set to all output to Tray 2, outputs to tray 1. Copier NOT in limited function mode. Done MMI clear, swopped Finisher Controller PCB, set up tray home position sensors, checked stapler movement /home position. HELP
  • watson
    • Sep 2009
    • 64
    Did you try and initialize the sensors?
    • teckat
      • 16083
      Under the limited functions tab now there are two pages for limited function.
      Be sure to check both pages.
      It has been found that if you change service mode level 1 Copier>Option>Body TR-SP-C1, TR-SPC2, TR-SP-C3 and TR-SP-C4 and if the value is set to 2 on the paper source you are running, everything will be delivered to tray A. TR-SP-C1 is for the paper type. C1 is for the right paper deck, C2 is for the left paper deck, C3 is for drawer 3, C4 is for drawer 4, MF is for the bypass and DK is for the side paper deck.
      also >>>u can try Performing>
      Additional Functions > Common Settings > Initialize Common Settings ,it may correct the problem.
      Note- that any changes made by the user under Common Settings will be returned to the default state,if u perform this-
      imageRUNNER 7086 / 7095 / 7095P / 7105 Adjusting the sensor intensity on the Finisher V1 / V2
      How to determine which number in the 7 segment led corresponds to what sensor during
      the Finisher V1 / V2 sensor intensity adjustment.
      Solution :
      To view the complete Sensor Intensity Adjustment, click on the attached PDF file.
      Adjust Finisher Sensors.pdf
      • liffy
        • 15
        Thank you very much for the info.
        I had changed the values of TR-SP-C1 etc to try and eliminate intermittant faint copy problem ( as on ir9070/8070/105+)
        All fixed now
        • teckat
          • 16083
          All fixed now
