my Ir 4570 got copies like zebra(black and white) i replace the Drum but just about 1,5 k of copies the problem is becomes again. i replace the drum twice but its still happen. please help me.
black and white copies on IR 4570
Your possibilities are drum,developer or hvt. My money would be on the dv unit. Has somebody messed with the settings in service mode? Check in service mode Copier>Adj>Develop and see if the setting is 115-120. Make sure that the contacts for the drum unit on the hvt are clean. If your using a generic drum unit and they are failing early ----switch to oem drum unit to see if that resolves issue. And.....as always a pic would really help us to give better advice.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
Where are you located? In the USA precisionroller sells them and shipping is free.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
