IR2022i Send Report
  • PoonKing5000
    • Jun 2008
    • 111
    IR2022i Send Report
    Does anyone know if there is a way to disable the TX Send report but leave the TX Fax report enabled on the IR2022?
    On the bigger machines they separate the two in Report Settings but not this machine.
    Andy
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1247
    Here's the book you need.
    If you look in chapter 11 of the fax & send guide it shows the available settings.
    I couldn't find any info there that makes it possible to do what you want.
    • teckat
      • 16092
      NO WAY
