imagePRESS C1 E748-4000
  • Dimacop
    • 43
    I have this copier showing this error
    not have the service manual
    anyone have any idea what can be
    I was told that may be in the G-chip?
    not found in the manual
    and a board
    appreciate everyone's help
    Att:
    Roberto
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Poor Contact Occurs PCB
    Remove the screws fixing the controller box
    cover
    Hold the Sub PCB firmly with both hands, and
    then pull out it from the main board.
    Clean the terminal (both adverse and back sides)
    of the detached PCB with lint-free paper
    impregnated with alcohol.
    With the Sub PCB [4] temporarily inserted,
    temporarily fix the Sub PCB support plate [5]
    with 2 screws. (Leave a space of approx. 1mm
    between the seating surface of the screws and the
    support plate.)
    Good luck.
    • teckat
      • 16083
      and a board
      Att:
      Roberto
      E748-4000 CL2 board-dependent, board error.
      A packet timeout condition has occurred in the G-Chip loopback.
      1. Disconnect and then connect 4 to 5 G-chip boards several times.
      2. Replace the G-chip board.
      3. Replace the main controller PCB.
      here is the full pdf below that
      zoraldinho posted
      TP08-1.pdf
      • zoraldinho
        • Mar 2008
        • 5007
        zoraldinho posted
        [ATTACH]9799[/ATTACH]
        Good assist my friend!
