how to setup gmail on ir2525 machine
  • lemko
    our company just switched email providers to google, and for the life of me i can't set the machine up to use gmail's accounts.
    i've changed the ports, the server names... i set authentication to on for smtp, recycled the power.
    but sending still fails. i am now starting to think this machine does not support ssl at all. is this correct?
    we received this machine a few months and specifically needed a machine with emailing capabilities. i fail to understand how a machine this expensive can't handle such an operation.
    any help would be much appreciated. thank you.
  • lemko
    i guess i found an answer to my problem while searching:
    http://www.copytechnet.com/forums/ca...on-ir2525.html
    if this is true... then this is very disappointing. will be contacting my reseller regarding this.
    • hector2309
      you can use IIS mail service and there to make a relay
