Register Firmware
  • Dedy.P
    • 67
    Register Firmware
    Hi..
    i have register firmware iR9070 or iR8070 to SSTv433Ez, but becomes invalid (red word) in job of SST
    but when i downgrade to SSTv411E in fine (black word), any idea?
  • Dedy.P
    • 67
    please,can anyone help me, that got same experience with my problem ?
    • Joe Karanja
      • Jun 2009
      • 12
      Dedy,i do'nt realy understand your problem.After trying to register the firmware under SST 4.1 is it working or still not working.If not your firmware is corrupted.
      • Dedy.P
        • 67
        when i register the firmware under SST 4.1 is working, but after i change the SST to v433, the firmware becomes invalid.
        maybe you're correct, my firmware is corrupted
        • ymmtech
          • Jun 2009
          • 190
          Corrupted files were the blame?
          Canon have made it easy, all the .prg, .dat, .ift files came with check sum.
          eg
          This file:ir2200-usen4501-5af7.prg. has 16bit check sum of 5AF7
          This file:iR8070-XXde1301-C76D-RUI.dat has 16bit check sum of C76D
          Have mentioned how to check sum. http://www.copytechnet.com/forums/ca...tml#post104743
          I am quite sure u got 0 corrupted file, neither a corrupted Zipped file, but more likely an old version firmware. So, if u got a latest one, share with me, Boleh pak?
          • bosty171
            • 12
            I had problems upgrading IR8070 with SST 4.xx
            Use older SSt and upgrade is OK and machine works fine.
