Canon 3220 printing and copying at a poor quality. Help Please
  • NeonDoorMedia
    • May 2011
    • 17
    Canon 3220 printing and copying at a poor quality. The images come out blurry as if taking with a poor quality camera, but that is not the case. Any suggestions?
  • ikon01
    • Apr 2011
    • 53
    post an example,sounds like your itb may need replacing.
    • NeonDoorMedia
      • May 2011
      • 17
      How would I do that?
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Do what??
        How would I post the example, or, How would I change the ITB???
        • teckat
          • 16083
          see pdf>>>iR3200-3220 ITB Issues TP03.pdf
          • NeonDoorMedia
            • May 2011
            • 17
            Here is what it's looking like
            Here is should look like and what it's looking like
            • NeonDoorMedia
              • May 2011
              • 17
              I already cleaned out the ITB and nothing changed.
              @Teckat Thanks for the instructions on that part it really helped.
              • teckat
                • 16083
                are u trying to make a copy off the Glass ??
                if so, place a sheet of clear Transparency on the glass / place the photo on top,close cover,select PHOTO on control panel > print out
                Another Note>>If heavy stock or glossy paper is to be used,
                ensure when performing Auto Gradation that heavy paper is selected and used when printing the measurement pages.
                • NeonDoorMedia
                  • May 2011
                  • 17
                  No. Im printing directly off my computer.
                  • teckat
                    • 16083
                    did someone send u the pic in an e-mail/ ??
                    what kind of paper are u using in the 3200 to print pic ?
                    • NeonDoorMedia
                      • May 2011
                      • 17
                      I took the pic myself with a good quality cam. And Im just using regular copy paper, but it looks the same on glossy.
                      • Smiley27
                        • Apr 2011
                        • 160
                        Hmm,could you post more photos? so we can judge :P .. (A)
                        • charm5496
                          • 2387
                          have you run autogradation? did those test prints look alright?
                          If so I would dump your print driver and reinstall.
                          do you have an imagepass attached to this device?
                          make sure you are grabbing the proper model either the 3200 or 3220. There is a difference.
                          If you have an imagepass attached then you will have to download and install the proper model for it as well which could be the C1 or C2 modelsimagePassC1_186x279.gifIf you one installed it would look like the picture attached. Let us know the exact model and if you an imagepass and then we can point you to the correct print driver.
                          I would also use the PS driver if you are printing pictures.
                          • NeonDoorMedia
                            • May 2011
                            • 17
                            I have the 3220 and C1 model
                            • NeonDoorMedia
                              • May 2011
                              • 17
                              Yes I did run autogradation and the prints looked good.
