How do I clean the ITB on a Canon IR c3220?
  • NeonDoorMedia
    • May 2011
    • 17
    How do I get to the Intermediate Transfer Belt to clean it out on a Canon ir c3220? Where is it located?
    -Thanks
  • Brian8506
    • 1666
    Judging by your name, I'm guessing you're not a tech. Better call someone who knows what they're doing with that machine
    • sniper2g8
      • Jan 2013
      • 117
      Re: How do I clean the ITB on a Canon IR c3220?
      -Thanks
      It is located at the right side where the bybass is. just press the push button to bring the bypass out you will see a screw there unscrew it there is the ITB
      • V-P
        • Apr 2011
        • 679
        ITB is not some cloth that you "clean it out".
        There should be smth like "Clean inside Main Unit" in the menu of the copier that would do the cleaning for you.
        That would do the job.
        • Brian8506
          • 1666
          My guess is after almost 2 years she probobly had someone take care of it. Just a guess.
          • Fer
            • Nov 2009
            • 267
            As longs if there is no misregistration anyone can try internal cleaning from the adjustments menu or replace the cleaning blade, that one is easy.
            • teckat
              • 16083
              Originally posted by neondoormedia
              how do i get to the intermediate transfer belt to clean it out on a canon ir c3220? Where is it located?
              -thanks
              i assume no responsibility
              this pdf is for trained techs/ others beware of damage to unit or printer
              [ATTACH=CONFIG]19109[/ATTACH]
              • SCREWTAPE
                East Coast Imaging
                • 3396
                May the force be with you!!! HA , AH , AH
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  -Thanks
                  No offense! But if you look like that in the avatar. I would fix it for a small fee!!
                  O, aren't you trained on this model???
