C3220 registration
  • repeatcopiers
    • Sep 2008
    • 591
    C3220 registration
    Have a C3220 that when you hold the original up to the copy, the top of the page lines up but then gradually shifts image to the left. Also color is blurring. We swapped out a transfer belt unit from another copier and still same problem. We also performed the DCon Clear. Any other ideas? I noticed on a previous post something about a Laser Adjustment.....could this be the issue?
    Image shift is happening on color and b/w.
  • charm5496
    • 2387
    It could be your lasers and if you do a search on the forum about this issue there are several and the instructions on how to reset the lasers are in one of those threads.
    And just because you swapped the ITB doesn't mean your ITB drive assembly isn't worn and need of new gears.
    • repeatcopiers
      • Sep 2008
      • 591
      Also, this copier won't perform a Full Gradation Adj. It keeps saying to place the test page on glass properly or something like that. Does this give us an indication of something in particular?
      • charm5496
        • 2387
        yes your image is not properly aligned on the page. Most likely because your image is being stretched or shrunk like you were describing as it goes down the page.
        This could also be from your paper not being alinged in the tray correctly. Or it could be a feed/registration issue but I doubt either one since you have an image alignment issue
        • Luther
          • May 2006
          • 682
          Also the itb cleaning blade can cause this as well as drag from the fuser the lower roller gets flat spots
          • KCTech
            Also be sure to check that the white cams that engage the ITB. Pull the ITB out and if you look in the machine there are 2 white cams one front and one rear. When you raise the blue lever behind the front cover above the waste toner bottle, those cams should cam up. Sometimes those can break, usually you can see the ITB sitting in the machine slightly uneven.
            • teckat
              • 16092
              READ PDF>>>>>iR3200-3220 ITB Issues TP03.pdf
              • repeatcopiers
                • Sep 2008
                • 591
                Thanks teckat, I did find where you attached this on another post......alot of help. Looks like the Swing Gear Assembly is my problem. Thanks again.
