Canon IR1022IF - IR Toolbox - "No Scanner Selected" "No Scanner Installed"..
  • ssgb
    • Aug 2025
    [Error Code] Canon IR1022IF - IR Toolbox - "No Scanner Selected" "No Scanner Installed"..
    Hi Folks.
    This printer has been driving me crazy for 2 weeks now.. The printer & fax work fine. However I just can;t get the machine to scan:
    I have installed the IR Toolbox for the IR1022 when I fire up and click on scan I get the follwoing errors:
    "There is no scanner selected. Please select a scanner"
    "A supported scanner is not installed. Please install a supported scanner, and then restart Toolbox."
    Any help would be a welcome relief!!!
    Thanks.
  • ciaran
    • Mar 2011
    • 45
    depends what cable you are using to connect, with the ir toolbox as far as i know you need to be connected to the ir1022if using usb. or else forget about the ir toolbox and use scan to folder/email
    • ssgb
      The printer is plugged into a switch. I have downloaded scangear on my pc, however this does not pick up the scanner...
      How can I scan to folder/email??
      Thx.
      • ciaran
        • Mar 2011
        • 45
        this should help you
        • teckat
          • 16083
          iR1022.pdf READ PDF
          iR1022if has it all /are u a tech or end user ????
          • Mina Banoub
            • May 2011
            • 50
            Hi,
            the ir1022 toolbar is just a scanning application (tool) but it`snt a driver,so,u have to istall the scaner driver which as i experienced befor doesn`t exist on the canon` support . All u have to do is to find an original setup CD that will finish your problem and will automatically install the scanning driver.
            • THUK
              • Jul 2008
              • 195
              hi i had the same problem on a 1024 and the only war round this is to plug USB into pc and load IR tool box software on as a administrator,it took me about two weeks to sort my one out.
              Originally posted by Mina Banoub
              Hi,
              • teckat
                • 16083
                iR ToolBox v4.09 for imageRUNNER 1023 Series (Supports Windows Vista 32-bit and 64-bit)
                • lottje
                  • Mar 2014
                  • 12
                  Last edited by lottje; 03-11-2014, 07:58 AM. Reason: Forgot I had a USB cable connected
                  • lottje
                    • Mar 2014
                    • 12
                    Re: Canon IR1022IF - IR Toolbox - "No Scanner Selected" "No Scanner Installed"..
                    Ok, so I just read on the Canon site that the USB cable won't work for scanning, guess I need to get a networkcable after all and hope for the best....
                    • spectraindo
                      • May 2008
                      • 313
                      As far as I know, the iR1022 and iR1024 Scans only via USB, network scanning is not supported.
                      Plug the ir to the PC using USB cable and install iR Toolbox and Fax Driver (the Scanner driver is in the fax Driver).
                      • ernesto
                        • Oct 2011
                        • 430
                        i am sorry about
                        • teckat
                          • 16083
                          What is your exact model
                          The iR1018, iR1022A & iR1022F come with UFRII and require a network adaptor.
                          The iR1022i & iR1022iF come with UFRII & PCL and network adaptor as standard.
                          SEND FUNCTION=Standard for iR1022i/22iF only
                          DADF
                          =Standard for iR1022A/22F/22i/22iF
                          PRINTER FUNCTION
                          =Interface (Standard)
                          iR1018/22A/22F Ethernet (100Base-TX/10Base-T) optional, USB2.0
                          iR1022i/iF Ethernet (100Base-TX/10Base-T), USB2.0
                          iR1022.pdf
                          • bipc
                            • Sep 2009
                            • 194
                            Life is a learning continuum...
                            • mramlawi
                              • Jul 2011
                              • 838
                              i have faced the same problem in win7 64bits and after a deep searches and tests i found the right driver send me your mail to send it for you and it will work safely.
                              Distinguished road makes you jewel in rough
