Hi Guys!
I've got a really funny problem...even it isn't funny
So I've got an IR2020 that makes jam at the registration roller , namely the registration clutch doesn't give any drive for the roller.
I've test it at open door.When test it at open door the first two pages come out ( of course the reg. roller doesn't spin) but it goes trough the machine so no jam occurs elsewhere).
You would say change the clutch, I've done it and nothing has happened and the most interesting is when the machine test itself the clutch works. When it test itself it works properly but when it prints it doesn't work or spin.
Think that it's some kind of DC panel problem or not getting enough Voltage but why does it work at the test and why doesn't at when it should work?
It has been already updated with the lates firmware from the Canon tech site and ALL Clear
but without any effect .
Anyone who has met with this? Or any idea?
Sorry I can't give you jam code as it always stuck.
Thank you in advance!
Norbert
Norbert
