Canon ir 3570 send kit transfer
  • berci
    • Aug 2025
    Please let me know if it is possible to transfer the license of the Universal Send Kit B1 from one iR3570 to another
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Yes you can.Need to deactivate old license in service mode,send to Canon together with serial
    number of new machine and you get new license.
    • teckat
      • 16083
      To transfer the license for an optional kit (ex. Universal Send Kit, Security Kit, Universal Send PDF Enhancement Kit, etc) to another imageRUNNER.
      the procedure to disable the license on the current imageRUNNER> SEE BELOW
      When transferring your key from one copier to another, you must make sure to disable the License Key on the imageRUNNER you are transferring from. The copier will then generate a transfer key number.
      You will need this number when you call the Technical Support Center to transfer the license.
      Please follow the procedure outlined below:
      1. Enter into Service Mode on the copier (hit Additional Functions, then 2 and 8, then Additional Functions).
      2. Enter Level 2 in Service Mode (hit Additional Functions, then 2).
      3. Press Copier.
      4. Select Option.
      5. Choose LCNS-TR.
      6. Set the appropriate kit option to 0 (ex. for Universal Send Kit, set ST-Send to 0). Hit OK.
      7. Write down Transfer License Key (ex. TR-Send) generated by the copier under this setting.
      8. Call the Technical Support Center with the device serial numbers and the Transfer License Key.
      * Make sure you have this number (Transfer License Key) handy when calling the TSC. This number must be provided to ensure that the License was indeed cancelled on the imageRUNNER.
      Contacting the Technical Support Center:
      Contact the Technical Support Center at 1-800-528-2830 to transfer a license from one device to another. You will be required to have the following information:
      1. The serial number of the old device.
      2. The serial number of the new device. (Verify that this serial number exists in your dealer inventory).
      3. The Transfer Key number.To get the Transfer Key number, you will have to disable the license on the old device (see above).
      4. Have the orginal LAN number
      You only need to call the Technical Support Center to transfer the license from one machine to another machine. You do not need to call the Technical Support Center to disable the license on a given machine. Simply follow the procedure above to disable the license on your device. Write down the resulting Transfer Key Number and the serial number of the device that you disabled the license on. Also write down the License Access Number for the kit. Keep this information in a safe place. When you have the serial number for the new device that you want to transfer the kit to, then call the Technical Support Center with all of the above required information. The Technical Support Center staff can then transfer the license in the LMS system and generate a new license key number for your new device.
      • berci
        Thank you for the information.
        I must call the Technical Support Center or I can use the online License Management System (https://c-lms.com/license/enduser/portal/LAInput.jsp) ?
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          It requires a call to the center, as this is not an automated process like applying the license in the first place. They have to back out the old license manually...
