ir3570 reader problem
  • rajmer
    • Dec 2008
    • 22
    Hi!
    I have a problem with my Canon IR 3570,when i put the originals in the dadf for one sided copy only,the feeder always scan double sided.If anybody have problems like that please advise me.
    THX
    • 16083
    Originally posted by rajmer
    Hi!
    THX
    Disabling idle feed mode on single sided copying through the DADF-
    When single side copying through the DADF, the original will cycle twice (idle feed) before being delivered.
    To disable this function, enter service mode level 2 > COPIER > OPTION > BODY ><SCANSLCT set to "0">. This will cause the original to cycle once and be delivered.
    also++++
    If u are using different/mixed size originals
    Check the setting under COPIER>OPTION>BODY>LEVEL 2>SCANSLCT. (*28*-in level 2 (*2 )
    COPIER>OPTION>BODY>SCANSLCT.) There are two settings available.
    0: OFF (Determining the scan area by document detection)
    1: ON (Determining scan area by paper size)
    If the setting is "1" the feeder will scan the original twice. Set to "0" for single scanning.
    • rajmer
      • Dec 2008
      • 22
      Thanks for the advice i will try to fix the machine tommorow and let you posted
      • rajmer
        • Dec 2008
        • 22
        i fix the problem thanks TECKAT
          • 16083
          thanks~~~~~~~~~~~~~~~
