IR105 with E350-001
  • Pilotpor
    • Jul 2009
    • 30
    [Error Code] IR105 with E350-001
    My IR105 show Error Code E350-001. That's no informaton in service manual.
    What happen with my machine. Please help me! Thank you.
  • V-P
    • Apr 2011
    • 679
    I don't know exactly what but :
    It is related to the brains of the copier. Probably main board or communication of main board.
    Try to remove and re seat motherboard.
    I found this:
    E350 Faults on ECO ID PCB. A check is made at poweron.
    1. Ensure connector J1213 on the Main Controller PCB is connected.
    2. Replace ECO ID PCB
    I am sure Teckat knows the exact issue.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      V-P is wright.It's communication of main board.Re seat connectors and install System Software Ver. 86.02.
      I hope you are not playing with the counter reset.
      • V-P
        • Apr 2011
        • 679
        you didn't mess with the counter - did ya ???
        • Pilotpor
          • Jul 2009
          • 30
          V-P,you mean counter pcb?
          • victor_v
            • 71
            Hi,
            E350
            1. The bar code data for backup and the attached bar code data do not match
            2. A fault in the Serial No. PCB is detected when power is turned ON
            Hardworking people are not present. Simply many it is boring to idle.
            • zoraldinho
              • Mar 2008
              • 5007
              Good point
              • V-P
                • Apr 2011
                • 679
                I mean...
                It's ok if you messed with counter.
                All you have to do is give a beer to me and zoraldinho
                and we tell you how to fix it ....lol
                • CT Copier Repair
                  • Mar 2010
                  • 304
                  playing with the counter will screw ya
                  make sure the bc is clean and readable
                  make sure the eco bd is seated and it wasn't swapped out
                  like trying to play with counters
                  sheeshs resetting counters is easy and not as involved as one might think
                  however its illegal and immoral and just plain scumbag move
                  • Pilotpor
                    • Jul 2009
                    • 30
                    How can I do with my machine?
                    Where is the ECO ID PCB?because i'm not technician.
                    • Pilotpor
                      • Jul 2009
                      • 30
                      To V-P,Zoraldinho
                      If I near you, I'm sure to give a beer to you all.
                      • V-P
                        • Apr 2011
                        • 679
                        don't know about Zoraldinho but as for me:
                        I am close enough - lol
                        • Pilotpor
                          • Jul 2009
                          • 30
                          What do you think that the first thing I could do with my machine?
