IR2870 Sorter SW1 SW2 infomation.
  • ymmtech
    • Jun 2009
    • 191
    Hi, Dear gen, Have machine always got paper jammed at sorter. Had conformed something wrong with controller board. will be gread if someone can share with me the sorter service manual, or the sw1 sw2 switch information, or which IC/Transistor was down...
    Please teach me how. Thanks.
    • 16083
    What Finisher model ??
    S1/Q3/Q4 ???
    What are the error codes or Jam codes ??
    • ymmtech
      • Jun 2009
      • 191
      S1 finisher, controller board 4G1-1478.
      Paper jammed without error code as shown on photo.
      Have confirmed it is something wrong with the controller board.
        • 16083
        Now I got 5 pieces of these board having same problem.[ATTACH=CONFIG]10161[/ATTACH]
        What is with that paper Curl ??
        With no Error code or Jam code Printer probably thinks paper has been delivered ??
        have u checked I/O for sensor readout ?
        ??? Have u checked if any of the Fuses Blowing out on those Pcb's ?? A good fuse will read 24 volts DC on both sides of the fuse. A bad fuse will read 24 volts DC on only one side of the fuse.
        Try & do a reset and clear the memory of the Finisher Controller PCB's.
        With the copier "ON'>>
        1-Turn ON all 4 dip switches
        2-Cheat the finisher door switch
        3-Press and hold SW2 until the LED stops flashing
        4-Then turn off copier
        5-Turn off dip switches and turn copier back on
        Check to see if the finisher initializes and if the problem is resolved.
        if fails>>>>
        Check accessory power supply .
        On J647, check pin 1 for 13 volts and pin 3 for 1.4 volts to determine if the accessory power supply is outputting properly.
        • ymmtech
          • Jun 2009
          • 191
          Thanks teckat and petersim for giving me a hand.
          The problem was cause by a jammed stack tray, M1 overloaded.
          Luckily, no toast yet.
