Hey there, I just got a ImageRunner 2200, and big surprise, parallel port with no printer function. Awesome!
I understand that I need the upgrade and as usual, its a ram upgrade + ethernet port card. What I do not know its the correct part # (If there is one) and the actual name of the part.
I found one on ebay that's called "AZ"?
Here's the image of the ethernet board:
If I do find the correct part, do I need a firmware upgrade? If so, is it included with the part with some sort of program? Thank you.
P.S. Can I upgrade this machine to cut off limbs?
