Scan to default JPG file in IR 2525?
  • kazihaha
    • 100
    [Misc] Scan to default JPG file in IR 2525?
    How can I set default scan to JPG? The default setting on IR 2525 now is TIFF.
    https://sieuthithietbivanphong.com
  • teckat
    • 16083
    To store your desired Scanning Mode settings for Send Jobs: 1. On the Send Tab, pull down the Scan Settings drop down menu and select Option.
    2. The Scan Settings configuration window will open. Set the options you want on this screen (ex. Resolution, Document Size, Special Features such as Job Build and Different Size Originals, etc).
    * Note - If faxing, be sure to select a supported resolution for faxing (normal - 200x100, fine - 200x200, superfine - 200x400, or ultra-fine - 400x400).
    3. Click the Store/Erase button.
    4. Select a Scanning Mode item on the left by highlighting it. The Scanning Mode items listed on the left are different groups of stored settings.
    5. Hit the Register Name or Store Name button to change the name of the Scanning Mode item selected.
    6. Press the Store button, verify the settings, and hit Yes to store your settings into that Scanning Mode item. Press Done.
    To change the default Send settings:
    1. Hit Additional Functions.
    2. Select Communication Settings (if a fax board is attached, you need to select TX Settings under the Common Settings column).
    3. Scroll to and select Edit Standard Send Settings.
    4. Set the Scanning Mode (you can select the Scanning Mode item stored previously), File Format (TIFF, PDF, etc), and Divide into Pages options that you want to be the new defaults.
    5. Hit OK.
    6. The device must be restarted for the new default Send Settings to take effect
    • kazihaha
      • 100
      5. Hit OK.
      Thank you very much Teckat. Also thanks to this forum and all members.
      • teckat
        • 16083
        • himynameisfa
          Re: Scan to default JPG file in IR 2525?
          Nice! Was wondering how to change the default. Thanks!
