imagepress server q1
  • alexctx
    • Dec 2010
    • 157
    code which is part PCB ASSY VIDEO BOARD imagepress sever Q1?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Fe1-6121-000 uib pcb ass'y
    • alexctx
      • Dec 2010
      • 157
      that is not.
      where to connect the interface cable.
      Approximate cost
      VIDEO PCB ASSY
      • teckat
        • 16083
        Originally posted by alexctx
        that is not.
        Approximate cost
        VIDEO PCB ASSY
        your lucky day
        SEE PDF>>>>>>>>>>>>>>Q1_I&SGl.pdf
        • alexctx
          • Dec 2010
          • 157
          does the code part
          • teckat
            • 16083
            Chapter 4> 4-10 page 50
            imagePRESS Server Q1
            FE1-6112-000
            IMAGE CONTROLLER PCB ASS'Y
            =( Copier interface board )
            The copier interface board provides the print interface between the imagePRESS and the
            copier.
            The copier interface board is installed in connector J12 on the motherboard and occupies
            slot 1 on the back panel.
            The interface connector available at slot 1 connects to a cable that attaches to the copier.
            • teckat
              • 16083
              if u need this Pcb, u better have it repaired,
              because cost of it to replace will make u faint
              • alexctx
                • Dec 2010
                • 157
                ok
                what happens is that when you send any inaccuracies just to process the copier comiensa the file disappears.
                and discard the problem with a good interface is pbc, I happened to other aviation contacts and was cleaned well.
                but it does not.
                and most strange is that passes the diagnostic test.
                it is as if the cancellation of the impression.
                I put a monitor, keyboard, mouse yen figure device manager as installed well.
                I think the problem is partly out of the card data
