Canon IR 3100c very low quality copies
  • chandra_mithra
    • Jun 2011
    • 16
    [Misc] Canon IR 3100c very low quality copies
    Hi everyone,
    I have a canon ir3100c photocopier. I had issues with error code E000020-0081 yesterday and it has been resolved yesterday itself. however now photocopy clarity is not good. The paper comes out with several lines in it especially in the color copies. I have cleared the waste toner and have cleaned the censor of the cartridges. still the copies are of very low quality. any help in this regard will be very much appreciated.
  • charm5496
    • 2387
    run a PG-10 to see what your developer quality is looking like. More than likely one of or all of them is in need of replacement and if your drum has more than 40K on it go ahead and replace it.
    don't forget to run the autogradation!!!
    • teckat
      • 16083
      Originally posted by chandra_mithra
      Hi everyone,
      an add to charm5496's response>>>
      E-020 sub code 0081
      Check the P-SEN-P reading in service mode Copier / Display / Dens / P-SEN-P. If value is less than 255 then go to service mode level two Copier / Display / Dens / P-LED-DA if reading is 90 or above then patch sensor is dirty or scratched. If reading is below 90 then drum unit is bad.
      + post a copy of your CQ issue
      • chandra_mithra
        • Jun 2011
        • 16
        sure. will try that once. if it doesnt work, then will go with the drum change. thanks
