Canon 730i E100 error
  • Jeff M.
    • Dec 2010
    • 127
    Have a 730i giving a E100 error. Book says is scanner failure. Not very familiar with this one, any advice would be greatly appreciated. thanks..... Jeff M.
  • charm5496
    • 2387
    more than likely your unit needs a new laser unit which is on top of the unit in the middle. A service manual should give you instructions on how to accomplish this. It takes around 30 - 45 minutes to replace
    • Jeff M.
      • Dec 2010
      • 127
      Thanks for your reply. Duh, scanner...laser... had optical scanner on the brain, not printing. Should have thought of that. I'll let you know how I make out. Thanks again.... Jeff M.
      • Jeff M.
        • Dec 2010
        • 127
        Not the laser, was the ECU board. Thanks for your reply. Jeff M.
