canon iR3100, E000674-0001 error.
  • zuluzzza
    • Aug 2025
    Guys,
    I need help with this error code... E000674-0001 for Canon iR3100.
    Thanks in advance!
  • universaltvm
    • May 2010
    • 52
    try this
    E674
    0000 A faulty occurs in the communication between the fax PCB and the main
    controller PCB.
    Main cause The wiring is faulty (short circuit, open circuit). The fax PCB is faulty. The
    main controller PCB is faulty.
    Making Corrections
    1. Wiring
    Are the connection and the cable between the connector J 1005 on the main
    controller PCB and the connector J31 on the FAX PCB normal?
    NO: Correct the connection and the cable.
    2. FAX PCB, Main controller PCB
    Try replacing the FAX PCB. Is the problem corrected?
    YES: End.
    NO: Replace the main controller PCB.
    • teckat
      • 16083
      Originally posted by zuluzzza
      Guys,
      Thanks in advance!
      E674-0001 can be displayed when the fax board can be detected, but cannot communicate with the host machine.
      Check the connector at J1210 on the Main Controller PCB.
      Make sure that the connectors are securely fitted between J1210 on the Main Controller PCB (Main) and the FAX board, and there is no pinched wires
      • zuluzzza
        Thanks guys! I will check the wiring.
