IP_C1_V66.04 system
  • alexctx
    • Dec 2010
    • 157
    IP_C1_V66.04 system
    I have a imagePRESS C1 IP_C1_V66.04 system I think is the last and has DCON 1601.
    vercion then that system has the DCON v21.01.
    com or come alone the publication.
  • charm5496
    • 2387
    that DCON version was a seperate release and is not included in version 66.04
    • alexctx
      • Dec 2010
      • 157
      thanks and I asked him canon.
      something else has come to actializar imagePRESS C1 that is not in the system 66.04
      • teckat
        • 16083
        still can't get that DCON v21.01 file to open/or registered in SST
        • alexctx
          • Dec 2010
          • 157
          canon. DCON gave me 21.01.
          sst normal load already. this file.
          the question was whether there is anything else to update.
          that is not within v66.04
          I do not speak English apology
          • teckat
            • 16083
            [ATTACH=CONFIG]10338[/ATTACH]
            How did u get v21.01 loaded ??
            u can now remove/delete v16.01
            • alexctx
              • Dec 2010
              • 157
              1. Reguistre her v66.04.
              2. Reguistre the file dcon v21.01.
              3. When he installs. Only he installs mas current.
              4. Mas that to update?
              Thank you for everything
              • teckat
                • 16083
                file type is not labeled correct, will not register in SST
                • mrfixit51
                  Lead Service Technician
                  • Oct 2008
                  • 1975
                  If I can muddy the waters up a bit,, if there is a batch file that installs the version 66.04, ALL or ALL_HDF, and if the 21.01 D-Con is not in that 66.04 version, you will have to individually load the different files under Single mode to the copier to insure that 21.01 gets loaded instead of a lower version D-Con that may have come with 66.04 system software...
                  • charm5496
                    • 2387
                    Haven't loaded a C1 in a while, but I think mrfixit51 stated it correctly that you have to do a single when installing it and choose that DCON file. I dont recall having any issues getting it to register either.
                    • alexctx
                      • Dec 2010
                      • 157
                      I agree with everyone.
                      Tomorrow will be installing this vercion.
                      the machine is under maintenance.
                      thanks for help
                      • teckat
                        • 16083
                        SST will not see it to register it/ downloads as unknown file type
                        Single will not see it either-
                        **click on pics for better view>>>>>>>>
                        this v21.01 .EXE file shown below>
                        when u click on the .EXE link this is the prompt offered
                        and this is what it looks like afterward>
                        this is what the file properties looks like after u download it
