could you tell me the procedure on how to connect sst to the IRC 3220. As I no longer use this software. Thanks
how to use sst 4.22e connect with the irc3220
Working from memory and assuming this is an upgrade, the IRC has an ethernet port and MFD boots.
Install SST.
Register system software into SST.
Connect laptop to IR3320 via ethernet. (X-over cable)
Set laptop ip address to 172.16.1.120.
Boot MFD whilst holding down the 1 and 7 keys until FIXIP is shown in top left of screen.
Enter Service mode of MFD (*28*)
Select>Copier>Funtion>Download The screen will display 'HOLD' next to the download key on the (touchscreen)
In SST select download software, select IR3320 ALL frm the list on the right hand screen, click download and follow the on screen prompts.
