c-1 help!
  • cedarstreet
    • Jun 2010
    • 44
    [Error Code] c-1 help!
    HELP!
    new error code that I can't find in my service manual - 197-0001 - looks to be related to DC control pcb - please tell my it isn't so - can't find the 0001 suffix -any help would be appreciated.
    • 16083
    Originally posted by cedarstreet
    HELP!
    E197
    0001-
    0004
    When a communication error occurs between the Fixing Feed PCB (Fixing Driver PCB, Feed Driver PCB) and the DC Controller PCB.
    U can try to remove and re-seat DC connectors
    before replacing DC PCB>>>>try and re-flash firmware-
    I have had success & other techs I know with re-flashing the C1
    on a few occasions .
    see updated error pub. for C1>>TP09.pdf
    • cedarstreet
      • Jun 2010
      • 44
      thanks for the help - I checked and reseated the connectors of the board - no avail - then called for service - they started searching for faulty wires in the fuser area - finally found a wire rubbing under the fuser belt but no arcing - he "reformed" wire to clear belt and the error went away - just wanted to add this to your massive knowledge base.
        • 16083
        give that tech an ATTA' BOY
        • cedarstreet
          • Jun 2010
          • 44
          One more update -About 100 clicks later the same error code came back - now the response is maybe the wire wasn't rubbing - maybe its a board or the harness - we'll get back to you - how do you retract the "atta boy"? Once more down machine in search of advice and help.
            • 16083
            Try and have the tech re-flash the Firmware/ if tech has it loaded on a USB stick / and if it is same ver. firmware on printer all u need to do is select Overwrite on screen
            or from Laptop u just re-load in download mode
