Hi everybody.
First of all, sorry for my english.
I have problem with finisher V1 connected to iR7105. After turn iR7105 copier on, display message shows error E542-80001. But, copier is switch off, finisher tray A is moved lower from line of the paper sensor and lower tray B is moved lower until it stop at botom of the finisher. Than copier is switch on, tray A is move by motor to its correct position, while tray B doesnt move at all. No message, no error. It is curious. When copier is switch off, tray A stay in position like in first example and tray B moved near to its paper detect sensor, but lower and switch machine on, than copier displayed error E542-8001. I changed tray motor(both,A/B), paper detect sensors for both trays, tray driver motor, tray rotate sensor. Finally i changed finisher controller. Nothing help.
Could someone help me?
Half the Kingdom for the advice.
