Np6551 uneven to almost blank copies
  • ericacah
    • Jun 2011
    • 12
    [Misc] Np6551 uneven to almost blank copies
    problem is that when i copy at cassette 1 letter size there is an intermittent or uneven copies and a little low temperature..and when i switch other cassette 2-4 the images will go light to blank..dev has toner/smooth rolling..
  • teckat
    • 16092
    Check the bias connector for the transfer corona
    Check the drum locking screw and drum support
    • ericacah
      • Jun 2011
      • 12
      thnx teckat...brand new paper fix it..
      • mr.daus
        • Apr 2011
        • 98
        humidity papper
        firdaus +(62)8195002007 firdaustrish@ymail.com
        • ericacah
          • Jun 2011
          • 12
          Originally posted by mr.daus
          humidity papper
          you're right sir..
          • teckat
            • 16092
            is your machine outdoors ??
            ha ha !!!
            keep unused paper in original wrapper/and keep the used reams flat and in a large (Rubbermaid) plastic covered container/ store all paper flat side down
            • ericacah
              • Jun 2011
              • 12
              ha ha !!!
              yes teckat...b4 i just leave unused papers in the cassette...definitely i'll do what you advice...
