machine is not detecting the finisher (N1), paper trays 3, 4 and the high capasity tray on the side.
ir c3220
That lower Cassette feeding unit supplies power to all those options /
there is an inter face square plug/ that goes from unit to printer/ unscrew cover on cable/ look inside to see if the two small connectors are seated in place/make sure that cable has no damage
Check for 24VDC at connector J486 pin 2 on the Pedestal Controller PCB.
PL.JPGPLUG3.JPGPLUG1.JPGLast edited by teckat; 06-24-2011, 09:10 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
It just dawned on me... DOH!!!!!!
If the power cord is not plugged into the proper place, only the main body gets power, and all accessories do not! I believe you place the power cord into the pedestal/paper feed unit, and the short plug from the pedestal unit into the copier main body..."Once a King, always a King, but once a Knight is enough!"
Give mrfixit51 a CIGAR
cra08-color.jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
I recall shooting myself in the foot on that on once, many moons ago. It seem that is how I learn a lot of life's lessons :-)
I replied to this problem once before, and posted a picture of the rear of one of my machines that was properly configured. Searching for that picture was not rewarded with the rediscovery of that image this time. I have so few of these left in the field, they were my favorite color machine..."Once a King, always a King, but once a Knight is enough!"
