canon ir 3570
  • jake24482
    • Apr 2011
    • 116
    [Jamming] canon ir 3570
    i got ir 3570 it keep on folding paper right before it reaches the drum. jam code is 0107
    i think paper has lots of humidity in it .is there any solution for humidity .is there any setting or heater for paper cassette please let me know if there is any thing
    thanks
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Procedure against Jam 0107
    thanks
    This should prove to be helpful with your problem, it has worked well for me...
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5005
      Do you have problem only with duplex printing?
      • jake24482
        • Apr 2011
        • 116
        most likely it is on double sided
        • zoraldinho
          • Mar 2008
          • 5005
          Pull out two black rollers on delivery tray.
          • mrfixit51
            • Oct 2008
            • 1975
            Originally posted by Canon.Tech
            [ATTACH]10535[/ATTACH]
            This may help you, I have found it to work very well.
            That is the same article I already posted,, great minds on the same track. This also helps with single sided jamming...
            Let us know what you finally discover Jake!
            • zoraldinho
              • Mar 2008
              • 5005
