How to reduce the speed of feeder for IRC6800 in Usend Mode
  • addoncopier
    • Feb 2010
    • 114
    I have a IRC 6800, i used the u-send to scan documents into the pc for storage. I found that the image come out from the scanning not align. It is due to the speed of scanning?
  • teckat
    • 16083
    Re: How to reduce the speed of feeder for IRC6800 in Usend Mode
    are u using the DF ??
    Check the document shutter fingers. If they are not fully retracting into the plastic guide, remove the pad underneath the shutter and re-test the DADF-
    When you scan images into a mail box or a file and then you print them, the images are shifted .
    Copies off the glass are good. ???????
    Solution :
    You must do image basic adjustments starting on page 13 -13 of service manual . Start by adjusting the image off the glass by adjusting registration and cassette position and then adjust memory print using ADJ X/Y in service mode under ADJUST.
