iR3530 Duplex problem
  • Peter Sim
    • Sep 2008
    • 445
    Greeting to all
    Need help.
    My current ir3530 machine having double side printing problem.The machine MN-Con is just26.02 , DC-Con 10.10 and Boot rom 08.38N
    Can some one help me with the firmware?Or any technical bulletin for me?
    Please PM me.
    Thank you in advance
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: iR3530 Duplex problem
    What kind of problem?.Post jam code.
    • Peter Sim
      • Sep 2008
      • 445
      Today when back and check.
      Most of the jam code are 0107 and a few with 0101
      • gensys
        • Jan 2011
        • 323
        0101 :> Jam Code > pick-up jam in multi feed ass'y
        You are checking > THE SEPARATION PLATE.....?
        It was found that >>>> the separation plate in the multi feed ass'y
        was warped and interfered with the separation roller,
        resulting in a rotational failure of the roller.
        Remedy > Check up or Replace the separation plate with a new one.
        The Road will be Mastered by >>> the Going...
        • gensys
          • Jan 2011
          • 323
          For JAM 0107 >>>> Read The attach >>>
          Good luck!
          • charm5496
            • 2387
            u really need to make sure your machine has the updated vertical path rollers, lower right door and inner guide assembly. without these mods you will have nothing but jam issues on this machine. The part numbers for the doors and inner guide are FM3-1296-000 and FM3-1297-000
            • Peter Sim
              • Sep 2008
              • 445
              To charm : vertical roller has been change to grey color type and with some modyfication on inner guide
              To gensys : i will try to follow the instruction on the bulletin but my Dc-con only v10.10 .Is there any early version bulletin?
              Thank you for all the reply.
              • teckat
                • 16083
                imageRUNNER 2230/2830/3530/2270/2870/3570/4570
                Firmware info>>TP08_320.pdf
                Stability of Pressure Applied by the Vertical Path Roller
                see PDF>>>>TP07-1.pdf
                Measure to Prevent Paper Jams due to the Wearing of the Registration Sensor Flag
                see PDF>>>>>>>>>TP07-2.pdf
                Corrective Measures against Pickup Jams and Lifter Failure
                see PDF>>>>>TP07-3.pdf
                • charm5496
                  • 2387
                  you still need the new inner guide and lower door though
                  • Peter Sim
                    • Sep 2008
                    • 445
                    Firmware info>>[ATTACH]10608[/ATTACH]
                    see PDF>>>>[ATTACH]10609[/ATTACH]
                    see PDF>>>>>>>>>[ATTACH]10610[/ATTACH]
                    see PDF>>>>>[ATTACH]10611[/ATTACH]
                    Thank you Mr teckat for the bulletin
                    Thank you once again everyone for the reply.
