IR C3100 calibration
  • cyberfix
    • Jun 2011
    • 10
    colors not calibrating correctly, for example, when printing black text other colored text appears in backgroup
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: IR C3100 calibration
    Probably itb cleaner.Post a pic.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1250
      I Agree,the transfer belt cleaning assy or drum unit is old and needs to be replaced. What's the life on the dv units?
      • charm5496
        • 2387
        we need a pic to see what the machine is actually doing....this also could be a fuser issue with flat spots, developers overtoning or image misalignment of the 4 developers.
        • gensys
          • Jan 2011
          • 324
          charm5496 > the rights, is necessary drawing
          The Road will be Mastered by >>> the Going...
          • cyberfix
            • Jun 2011
            • 10
            Thanks for the quick reply, will post images once I return onsite. I should also mention cyan and magenta leakage even after vacuuming internals, will order replacment cyan and mag developer units. Do these units need to be reset after replacment?
