intermittant vertical and hoizontal lines on page, usually both 2 cm thick. Not a particular color, marks seem to be composite. Vacuumed Drum Unit, toners and developer units and tested ok for around 100 pages before marks reappear. Any help would be much appreciated.
Canon IR C 3100
Re: Canon IR C 3100
Is this the same post like one before?Practice makes perfect
If you want something done right, you have to do it yourself
Re: Canon IR C 3100
Even I am suffering a similar issue with the my machine. I even had a new drum unit. The new drum unit has yielded nearly 360 copies & the marks in the copies have appeared again. Does moisture affect much ? B'cos we have had a very heavy rainfall in the past 3 days. Any suggestions?Comment
Re: Canon IR C 3100
Remember you have two clean blades in this copier, one in the drum, and one that cleans the ITB. If you have replaced the drum, then the ITB clean blade is your next best bet. I have on rare occasions seen the drum flip the clean blade as well, giving me dirty copies..."Once a King, always a King, but once a Knight is enough!"
