IRC 624 - Can't activate Ethernet Port
  • Tenk
    • Aug 2025
    Hi,
    I encounter a problem with a Canon IRC 624 and network printing. For some unkown reasons, network printing doesn't work anymore. I decided to try to change IP because I suspect an IP conflict on network but I can't access to protocol configuration anymore. It says I "need to activate a network port before" but in "Port Config", I can only access to parallel port. the "Ethernet Port" entry doesn't appear anymore.
    I tried to reset to "Factory Settings", but it didn't change anything. I tried to plug/unplug the mother board and plug/unplug ethernet cable to see if "Activate Ethernet Port" reappears but it doesn't.
    When I plug ethernet cable, "10/100" led is green lighted and "base" led is green blinked-lighted.
    (Tried to change RAM slot and CR2032 battery without success too.)
    When I print configuration, I well see that Ethernet port isn't activated.
    It seems to be an hardware problem, but maybe anyone have a clue on something else to try ?
    Thanks in advance for any help
  • gensys
    • Jan 2011
    • 323
    Re: IRC 624 - Can't activate Ethernet Port
    unistall ethernet ......
    reboot comp.....
    When Comp logined install ethernet drv.
    Check UDP cabel for error or change
    set ip
    set mask
    set gatewey
    in command promt > cmd> ping -t ???.???.???.??? ( ip adress your iR) see IP adress respons or not?
    firewall on or off
    check firewall
    Establish other ethernet card in PCI slot and try
    The Road will be Mastered by >>> the Going...
    • teckat
      • 16083
      call provider
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        To rule out IP conflict, simply keep the device off the network and ping the IP address, if there is more than one device on the network with the same IP, the ping will return a reply...
        • Tenk
          Hi,
          thank you very much for yours answers
          Actually, I've already ping IRC IP with and without cable and got no respons. Anyway after Factory Settings Reset, copier have no IP setted, I think. And there's no reason it should respond because Ethernet Port isn't activated.
          I called provider last month who told me contract has been expired (and they don't provide parts anymore).
          I wonder if the "Activate Ethernet Port" function may only appear if a network (so plugged cable) and no problem on it is detected or if it should be always accessible.
          He told me that it may should be always accessible but I know, by experience, this small enterprise doesn't know well this model.
          • teckat
            • 16083
            Originally posted by Tenk
            Hi,
            your service provider is a jerk
            • CanonSco
              Man About Town
              • Jul 2010
              • 368
              Had to google the model. Never seen one. They common out there?
              Yes, I am a nerd.
              Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
              • KL568
                _
                • Feb 2011
                • 324
                iRAC624 is "upgraded" of CP660.
                Tenk,
                Have you tried using a parallel cable to print from a laptop? I know it difficult to have parallel port with nowadays new laptop, but if you are able to print via parallel port, then you would have narrow the fault to NIC port.
                As this Fiery board's internal system runs variant of Linux, your last effort is re-install the it OS. If after that failed, I'm pretty sure the board is a goner.
                • Tenk
                  Thanks very much to everyone
                  Model isn't common out there, and it's not a very good color copier, I think (due of ~10 min to start and the 3 passes for RGB color copy make it very slow bit it's a very old model).
                  Thanks KL568,
                  I gonna try to get a parallel cable. I got a desktop PC near copier.
                  Do you know where I could find the OS if it's free ?
                  If re-install fails, we'll use it via parallel cable.
                  • Tenk
                    Actually, there's something else I'd like to try ; I'd like to execute the "diagnostic function" but copier ask to me for a for digits "Passcode". It seems to be different from the copier password because copier doesn't have a password. Maybe anyone knows what would be the default passcode ?
                    Thanks in advance
                    [Edit]
                    Well, I tried *28* (almost like copier service mode) and it worked for entering server service mode but I got same functions than copier service mode. I mean same informations are displayed on the little lcd server screen than on the big copier lcd screen in service mode, so nothing usefull for me
                    • teckat
                      • 16083
                      Service Mode
                      1) Connect the power plug to the power outlet; and while holding on the “Menu key,
                      Enter/Online key, and Cancel key” on the control panel at the same time -
                      “Start SELF-TEST” displays. The panel display will show “DISPLAY” to indicate that service
                      mode has started after the printer unit checks itself.
                      Main Menu
                      DISPLAY=Display mode is for displaying the status/configuration of the printer.
                      SENSOR MONITOR=Sensor monitor mode is for displaying the state of the sensors in the paper path of the printer unit.
                      TEST=Test mode is for checking while operating the printer unit.
                      PAPER FEED=Use it to pick up one sheet of paper from the selected pick-up slot and deliver to the selected delivery slot.
                      READ MEMORY=This mode is stored in the EEPROM on the printer board, and is used to read various backup data items (e.g., PARAMETER, BIAS) to the work area.
                      PARAMETER=Parameter mode is for checking the adjustment data specific to each printer unit and stored in the EEPROM on the DC controller PCB at time of shipment. Normally, it is the
                      data stored in the RAM on the printer board.
                      Changing each data item and executing memory write mode thereafter will update the
                      data in the EEPROM on the DC controller PCB BIAS
                      WRITE MEMORY=This memory is used to write the various adjustment data items (e.g., PARAMETER, BIAS) read into the RAM on the printer board to the EEPROM on the printer board and the EEPROM on the DC controller PCB.
                      • Tenk
                        Hi,
                        thanks, this menu seems interesting but I can't access it.
                        "Start SELF-TEST" is never displayed.
                        I got :
                        "EFI Bios 3.14 X3E Rev G"
                        "Loading System"
                        "System booting. Please wait..."
                        "Diagnostics in progress..." (during less than 1/2 second)
                        "Diagnostics passed"
                        "Wait"
                        and then after boot
                        "Infos iR_C624" (it's the server name)
                        I tried to keep pressed the 3 buttons during each of those steps but nothing appears.
                        I'll try to keep pressed the 3 buttons before starting and during all boot procedure (hard for my fingers )
                        • teckat
                          • 16083
                          sorry, that service mode was for CP660, I thought IRC624 was in the same family
                          of printers. I will see if I can find out more on your model.
