Color ImageRUNNER 4060i has code E000007-0211*
  • delosangeles
    • May 2008
    • 274
    [Error Code] Color ImageRUNNER 4060i has code E000007-0211*
    Hello everyone I have a client with a CIR 4060i displaying error code E000007-0211*I have most of my career spent servicing the Ricoh line of machines and I would be grateful for any input on this problem. Thank you all.
    Trade like a tiger sleep like a baby
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Color ImageRUNNER 4060i has code E000007-0211*
    Hello
    E00007-0211 = Error of temporary prevention of full displacement of belt
    Remedy:
    Replace the fixing unit
    To be sure:Go to service mode *simultaneously 28 * copier>counter>drbl1 and check FIX roller counter (%).
    • delosangeles
      • May 2008
      • 274
      Thank you for that info. I do not know the procedure for entering the Service Mode would be able to share that with me I also was wondering if I needed to clear a fusing unit counter? And if so which simulation it is. Thank you again for your generosity.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Reread Zoraldino's post,, he told you how to enter service mode!
        Fuser unit counter does not need to be cleared to resolve the issue. I assume this model is similar to the irc4080 series copier here in the U.S. The fuser assembly more than likely needs to be replaced, a very expensive part, and not for the casual service vendor. You may want to refer this to a Canon trained tech. It is not a simple part swap like on earlier models...
        • teckat
          • 16083
          E000007-0211
          belt displacement/ Error of temporary prevention of full displacement of belt (When a belt was displaced to the rear side and could not move to the center, the displacement of the belt was not eliminated within one minute in the belt displacement temporary prevention mode.
          Fixing Seizure Sensor bracket could just be broken if u are lucky/ if belt is not damaged/ tech can inspect and replace Seizure Sensor bracket - belt can be put back to center position
          As mrfixit51 stated u need a trained Canon tech
          Call for a Canon tech/ to inspect or replace Fix Unit/
