IR5070 service manual
  • brizzen
    • May 2025
    Hi, i need a service manual for canon5070. Can anyone help me?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Re: IR5070 service manual
    What is your problem?
    • brizzen
      I have been asked to change a laser mirror motor and would like to have instructions how to do this.
      • teckat
        • 16083
        Removing the Laser Scanner Unit
        Open the manual feed tray cover [1]; then, remove the screw [2] from the door strap, and fully open the manual feed tray cover [1].
        2) Remove the screw [1], and slide the developing assembly locking unit [2] in the direction of the arrow to detach.
        3) Remove the 4 screws [3], and detach the scanner cover [4].
        4) Disconnect the 3 connectors [1].
        5) Remove the screw [2].
        6) Remove the 2 screws [3] together with the inside
        spacer; then, detach the 2 leaf springs [4].
        7) Hold the front of the laser scanner unit [5], and lift and slide it out.
        When Replacing the Scanner Unit
        If the temperature of the fixing assembly is 150 deg C or higher when the main power switch is turned on, the machine will not execute potential control. If such is the case after replacing the scanner unit, manually execute potential control in service mode as follows:
        1) Make the following selections in service mode:
        Start service mode.
        (Press the (*) key, '2' and '8' at the same time, and the (*) key once again.)
        COPIER> FUNCTION> DPC> DPC; then, enter '1', and press [OK].
        2) Turn off and then back on the main power switch.
        • brizzen
          Fantastic, thanks a lot. I'll change it tomorrow.
