canon IR C 3200 discoloration , blurry and keep on waiting!
  • downhiller67
    • May 2010
    • 67
    good day!
    i really need help regarding my IR c3200, i haven't uses it for almost two weeks but when i going to print it show some discoloration and blurry image, i already clean the ITB and the rollers on it, but still no changes, so I called up canon service tech. but until now they haven't responded, its been almost a month. so i decided to turn it on again but this time it wont proceed to ready copy, the display say wait... i tried to re-slot the memory card but still no luck at all. please see attached pix.
    thanks in advance!
  • mr.daus
    • Apr 2011
    • 98
    Re: canon IR C 3200 discoloration , blurry and keep on waiting!
    wait : fixing temperature in not reach for 200
    firdaus +(62)8195002007 firdaustrish@ymail.com
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 4999
      Machine keep waiting because can not be calibrated.Use reading material and enjoy.You have a lot work to do.
      Cheers
      irc3200-019.pdf
      • teckat
        • 16083
        there are many post's in this forum concerning your issue/ do a search for iR3200 or iR3220 , with solutions displayed
        to add/ waiting message is usually bad memory or a HDD going bad
        there is a big difference between the following messages-
        Waiting
        Please Wait
        Waiting to Print
        Wait a Moment
        • downhiller67
          • May 2010
          • 67
          this is the display, its almost an hour keep on waiting.
          • teckat
            • 16083
            Try removing the boards plugged into the Main Controller one by one to try and isolate which one could be causing the problem. If all the boards check out fine you may have a bad SRAM PCB
            if u have an imagePass connected/ disconnect & remove it/ then power up
            • zoraldinho
              • Mar 2008
              • 4999
              This tipe of waiting have nothing to do with blurry prints.Like Teckat say,reconnect SRAM and DIMMS or in the worst case replace one.
              • downhiller67
                • May 2010
                • 67
                sir, i already reconnect SRAM and DIMMS, unplugged, and replace SRAM, but still no luck
                • downhiller67
                  • May 2010
                  • 67
                  done with the scan disk, "download mode" appear on the screen. do i have to wait for it? how would I re-install the firmware? can you please guide me.
                  thank you!
                  • teckat
                    • 16083
                    Canon Service Support Tool=SST
                    + the iR3200 firmware loaded in the SST
                    • downhiller67
                      • May 2010
                      • 67
                      whew! where can I get it sir teckat? whats the procedure?
                      thanks you!
                      • downhiller67
                        • May 2010
                        • 67
                        it doesn't work sir. i guess i need to re install the firmware. but my problem is where I could get those SST and firmware and the guide on how to do it.
                        realy need it very badly.
                        thanks!
                        • zoraldinho
                          • Mar 2008
                          • 4999
                          Originally posted by Canon.Tech
                          The firmware & the tool to install it are only available to Canon engineers. I don't know if you have a tech you can call out but this is your best bet.
                          Amen!
                          • charm5496
                            • 2387
                            You mean every joe blow shouldn't have a copy of this to mess of there equipment? LOL
                            • downhiller67
                              • May 2010
                              • 67
                              OMG,where the hell i could fine this thing! I doubt if the canon tech in our place has this SST & firmware. cause they don't sell this type of machine IR C3200. could someone has canon SST and firmware please help me.
