irxx70 series
  • Mina Banoub
    • May 2011
    • 50
    irxx70 series
    Hi everybody,
    can the irxx70 series perform an auto shutdown that can be adjusted at a certain time daily?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: irxx70 series
    no
    • charm5496
      • 2387
      Re: irxx70 series
      Originally posted by Mina Banoub
      Hi everybody,
      additional functions>timer settings>daily timer settings should shut the machine off like you want. I'm sure there is a thread in here with more detail on it....I'm sorry this just forces this model into sleep mode
      • zoraldinho
        • Mar 2008
        • 5007
        Re: irxx70 series
        Damn i'm old.Of course you can do.Charm is 100% wright.Daily timer settings.Honestly,I newer use this function.
        • charm5496
          • 2387
          Re: irxx70 series
          but does it shut it off or force to sleep? Going to test this out again...its been too long...lol
          • charm5496
            • 2387
            Re: irxx70 series
            the 8500 I am at goes into sleep mode.
            • zoraldinho
              • Mar 2008
              • 5007
              Re: irxx70 series
              IRC2380 also.
              • charm5496
                • 2387
                Re: irxx70 series
                you can set your machine to the lowest levels of power consumption while in sleep mode to get as close to shutting it off as possible. Other than that you will just have to manually shut the unit off every night.
                • Mina Banoub
                  • May 2011
                  • 50
                  Re: irxx70 series
                  thank you guys , but daily timer doesn`t shut down the machine. Actually I don`t think it does anything at all because ( as i know) the machine doesn`t support a calender that helps it to recognize the corresponding day for a specific date .
                  • charm5496
                    • 2387
                    Re: irxx70 series
                    you have to go in and set the time and date.
                    additional functions>system settings>time and date settings. there is a spot for timezone as well.
