IR5065 with error code
  • Pilotpor
    • Jul 2009
    • 30
    Today My IR5065 show Error Code E808-0002.
    I don't have service manual, What is the meaning of this error code.
    Plese help...
    Thanks.
  • charm5496
    • 2387
    Re: IR5065 with error code
    E808-0001 The IH power supply input voltages are higher than the stipulated voltages.
    E808-0002 The IH power supply input voltages are lower than the stipulated voltages.
    The remedy description for either code is to plug the machine into a wall outlet with the correct voltage and replace the fixing heater power supply. I would check your wall voltage and then put a meter on the IH power supply to see what your readings are.
    • Pilotpor
      • Jul 2009
      • 30
      thanks so much...
      • charm5496
        • 2387
        you are welcome. let us know if you need more assistance or what solved the issue
