Canon IR4570 E005-002 code
  • Zoollanderhu
    • Aug 2010
    • 76
    Hi Guys!
    I've got an IR4570 which has a E005-002 service code. I couldn't find it in the service manual, and dunno for what is it. I found the canon use it for cleaning web count Could it be?
    Or what else?
    Thank you in advance!
  • Zoollanderhu
    • Aug 2010
    • 76
    Re: Canon IR4570 E005-002 code
    Originally posted by Canon.Tech
    Are you sure you have the code correct?
    Sorry , Yes
    • mr.daus
      • Apr 2011
      • 98
      clean the fixing cleaning roller
      COPIER-COUNTER- PRDC 1- FIX WEB
      firdaus +(62)8195002007 firdaustrish@ymail.com
      • Zoollanderhu
        • Aug 2010
        • 76
        mr.daus, Since when did the Ir4570 have a web!?
        Yes unfortunatelly it hasn't got....so it couldn't reset the counter of it.
        What else can be?
        • charm5496
          • 2387
          never heard of this model throwing that code. curious at to what the solution end up being.
          • teckat
            • 16083
            What else can be?
            Post a picture of that code shown on control panel !!!!!!!!!!!!!
            I don't believe it---------------
            • Zoollanderhu
              • Aug 2010
              • 76
              The code is exactly :
              E000005-0002
              I will post a picture If I got from my partner
              I swear I'm also courious about the problem cause I still haven't found the problem.
