Changing ColorPASS GX-100 for imagePRESS Server Q1
  • Dimacop
    • 43
    I have and imagePRESS C1
    unfortunately came second GX-100 and a server Q1
    I noticed that machines are the same
    it is possible to change these two serves to act as Q1
    I have to do
    so replace the CMOS and the system installed?
    because I'm doing this and not working
    Anyone know where I'm wrong
    wait a help
    thanks
  • teckat
    • 16083
    Re: Changing ColorPASS GX-100 for imagePRESS Server Q1
    You can upgrade a Q1 to a Q2 !!
    imagePRESS Server Q1 Ver.1.1 to imagePRESS Server Q2 Ver.2.0. There is no hardware upgrade; the same hardware platform for imagePRESS Server Q1 can be used for the imagePRESS Server Q2 Ver.2.0.
    important to note, however, that a Q2 which has been upgraded from a Q1 will not support the use of Clear Toner with the imagePress C1.
    Don't think u can turn a GX-100 to a Q1
    • alexctx
      • Dec 2010
      • 157
      can not. each motherboard is unique. if you change the cmos (bios) says incompatible hardware, o. no valid license.
      or between two Q1.o two GX100.
      so when you buy a motherboar say they do not put the bios motherboar bad.
      can not. I've tried. but read this.
      • teckat
        • 16083
        Waste of time and effort
        • charm5496
          • 2387
          we had a tech try this and he ruined two motherboards in the process. Moral of the story is you can't do it.
