IRC2880i E748-4875
  • msmy
    • May 2010
    • 123
    IRC2880i E748-4875
    I have problem with IRC2880i. The error code appear when i swich on the machine. The error code is E748-4875. Anyone please give idea what the problem is.
    thank you.
    msmy
  • charm5496
    • 2387
    Re: IRC2880i E748-4875
    I would reseat all your boards, boot rom and RAM in your main controller. You might have a bad board or just a bad connection on one of them.
      • 16083
      to add on to charm5496's thoughts
      TP07 094[1].pdf
      • charm5496
        • 2387
        I tried finding this code and cannot locate it anywhere. did you move the machine or anything happen to it before this code appeared?
        • msmy
          • May 2010
          • 123
          Thank you both of you. I solved the problems as both of you suggested. I follow Procedure givent by teckat and it's work.
          thanks guys...
          msmy
            • 16083
            good find/ those pcb's cause a lot of issues if not seated properly/ or have dirty contacts
            • charm5496
              • 2387
              thanks guys...
              msmy
              Way to go!!!!
