canon irc 3100
  • aoseikwame
    • Mar 2011
    • 25
    canon irc 3100
    i have been having the code E000020 0291 please any help
  • chandra_mithra
    • Jun 2011
    • 16
    Re: canon irc 3100
    A computation result of patch reading in patch detection is 1008 or more.
    Check on toner leak from buffer in the developing unit. You may need to replace the patch image reading sensor.
    • teckat
      • 16083
      Re: canon irc 3100
      E020-0291= MAGENTA ISSUE
      Patch image reading sensor window=Use a blower brush or lint-free paper with alcohol.
      Never dry wipe.
      click on picture for better view-
      Trouble Shooting error code E020-xx10, xx11, xx12, xx90, xx91, xx92, xx93, xxA0, xxA2, xxA8, xxA9.
      XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
      There are several things that can cause E020's; ATR Sensor, Patch Image Read Sensor, weak Developer, DC Controller and Drum Unit.
      Some simple trouble shooting can help you isolate the problem.
      1. If possible make 10 color copies to force the ATR sensor to take readings.
      Then compare the SGNL reading for the color that is generating the error and additional colors in Service Mode; COPIER>DISPLAY>DENS>SGNL-Y/C/M with the Initialization setting in COPIER>ADJUST>DENS>SGNL-Y/C/M.
      COPIER>DISPLAY>DENS>SGNL-Y/C/M arethe ATR Sensor readings of the Developer in its present condition and should be within +/- 100 of the Initialization settings.
      COPIER>ADJUST>DENS>SGNL-Y/C/M arethe Initialization settings that the copier maintains and are usually between 400 and 650
      2. If the Initialization setting is outside these numbers the Developer Unit will need to be replaced.
      When replacing the Developer Unit, make sure to execute:
      - COPIER>FUNCTION>INSTALL>STIR-Y/C/M
      - COPIER>FUNCTION>INSTALL>INIT-Y/C/M
      - COPIER>FUNCTION>INSTALL>SPLY-H-Y/C/M
      After Initializing the Developer Units print a P-print and keep with the copier.
      -COPIER>FUNCTION>MISC-P>P-PRINT
      3. If the ATR Sensor reading is over +/-100 of the Initialization setting; the ATR Sensor, Patch Image Read Sensor, Drum Unit and DC Controller are suspect.
      Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE.
      The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each color and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is close to or over 100% of its rated life.
      If the Drum Unit is not close to or over its rated life, replace the ATR Sensor and Patch Image Read Sensor. If the error continues replace the DC Controller.
      5. If over toning continues to occur the Toner Supply Clutch (CL7) may be sticking and need to be replaced.
