Problem at double-side copying
  • gensys
    • Jan 2011
    • 323
    [Misc] Problem at double-side copying
    Greetings guys!!!!!!!!!
    Offset of axis Y (Ydirection) at the double-side press and copying.
    The first side prints ideally, but at double-side the machine the second side prints & copying the press with offset concerning axis Y ( Y direction) approximately on 8 millimeters.
    Original 2 side >>>> top 10mm, buttom 10mm, left 10 mm,right 10mm
    copy & print firth side >>>> 10mm 10mm 10mm 10mm
    second side >>>>>> 2mm 18mm 10mm 10mm
    Factory setings.
    ADJ -X 25
    ADJ -Y 83
    ADJ -S 50
    ADJ -Y-DF 55 (66)
    Other ideas
    The mashine iR6570.
    The Road will be Mastered by >>> the Going...
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Problem at double-side copying
    • gensys
      • Jan 2011
      • 323
      Originally posted by zoraldinho
      [ATTACH=CONFIG]10800[/ATTACH]
