Re: errcr code clear canon ir6000/ir5000/ir3300
Need service support tool and firmware and a lot of knowledge.
Guest repliedRe: errcr code clear canon ir6000/ir5000/ir3300
search online for any of these> most are old #'s
the original Canon OEM part is------
Hitachi Deskstar
HDS728040PLAT20 = WM2-5222-020
any of these will work
HDWN 'FUJITSU MPC3032AT
HDWN 'FUJITSU MPD3043AT
HDWN 'FUJITSU MPE3064AT
HDWN 'FUJITSU MPF3102AT
HDWN 'FUJITSU MHK2060AT
HDWN 'FUJITSU MPG3102AT E
HDWN 'FUJITSU MHN2300AT
HDWN 'FUJITSU MHT2020AT MF
HDWN 'FUJITSU MHV2040AH
HDWN 'QUANTUM FIREBALL CX6.4A
HDWN 'QUANTUM FIREBALLlct10 05
HDWN 'QUANTUM FIREBALLlct08 04
HDWN 'QUANTUM FIREBALLlct15 07
HDWN 'QUANTUM FIREBALLlct20 10
HDWN 'TOSHIBA MK6014MAP
HDWN 'TOSHIBA MK6015MAP
HDWN 'TOSHIBA MK1016GAP
HDWN 'TOSHIBA MK6017MAP
HDWN 'TOSHIBA MK2023GAS
HDWN 'TOSHIBA MK4032GAX
HDWN 'IBM-DJSA-205
HDWN 'IBM-DARA-206000
HDWN 'IBM-DJSA-210
HDWN 'ST34311A
HDWN 'ST34313A
HDWN 'ST310211A
HDWN 'ST340015A
HDWN 'ST92011A
HDWN 'ST340014A
HDWN 'ST940210A
HDWN 'IC25N006ATDA04-0
HDWN 'IC25N010ATDA04-0
HDWN 'IC35L040AVER07-0
HDWN 'IC35L020AVER07-0
HDWN 'IC25N010ATCS04-0
HDWN 'IC25N020ATMR04-0
HDWN 'Maxtor 2B020H1
HDWN 'MAXTOR 4K020H1
HDWN 'Maxtor 2F030J0
HDWN 'Maxtor 2F040L0
HDWN 'WDC WD400BB-22HEA0
HDWN 'WDC WD400BB-22JHC0
HDWN 'WDC WD300AB-00BVA0
HDWN 'WDC WD800BB-22JHC0
HDWN 'HDS722540VLAT20
HDWN 'HDS728040PLAT20
HDWN 'SAMSUNG SV2001H
HDWN 'SAMSUNG SV0211H
HDWN 'SAMSUNG SV0221N
HDWN 'SAMSUNG SV0411N
HDWN 'SAMSUNG SP0411N
HDWN 'ExcelStor Technology J120
HDWN 'ExcelStor Technology J64
HDWN 'Hitachi HTS541640J9AT00! I have the HDD' and I want the software and the the Canon SST
sorry for the inconvenience :/
Thank's a lot for your help .. so where can i find this new Hard Drive nourddine_troudi@hotmail.com
Hitachi Deskstar
HDWN 'IBM-DJSA-205
HDWN 'IBM-DJSA-210
HDWN 'ST34311A
HDWN 'ST34313A
HDWN 'ST310211A
HDWN 'ST340015A
HDWN 'ST92011A
HDWN 'ST340014A
HDWN 'ST940210A
HDWN 'Hitachi HTS541640J9AT00Leave a comment:
E602-0003 error code.
At times, a sector error occurs when the power is turned off while data is being written to the HDD. This will indicate 'E602-0003' and prevent the machine from entering service mode.
first try a HD-Check-
To execute this mode, hold down the '1' and '9' keys on the keypad for approximately 6-8 seconds. A flashing block will show in the top left corner of the LCD.
Normally, 'HD-Check' lasts about 15-20 minutes, and ends if no fault is encountered or specific sectors have automatically been repaired bringing up DOWNLOAD MODE on the LCD.
DO NOT STOP ONCE STARTED.In certain cases,"HD-Check" can take longer than 15-20 minutes and sometimes the machine can hang in this mode and will never complete.
if it returns an error-u need to get a new Hard Drive> & re-load printer firmware using the Canon SST (Service Support Tool)
Thank's a lot for your help .. so where can i find this new Hard Drive nourddine_troudi@hotmail.comLeave a comment:
if it returns an error-u need to get a new Hard Drive> & re-load printer firmware using the Canon SST (Service Support Tool)Leave a comment:
Guest repliedRe: copeur CANON IR3300 error E000051-0000
This code refers to a problem with the Horizontal Home Position Sensor, or the Horizontal Registration Motor M3.
check for broken gear on the Horizontal Registration Motor.
[ATTACH=CONFIG]14500[/ATTACH]
Gear- 14T / 56T-FS7-0750-000
M3 Motor - FK2-0144-000
check contact pin at intermediate connector J3040-2. This is the signal line for M3, the horizontal registration motor. Reform the contact pin if bent >to the proper position.
E051-0000- At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
[ATTACH=CONFIG]14501[/ATTACH]
Main Cause- The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
1. Connector
Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected?
a. DC controller PCB (J304) <-> relay connector <-> horizontal registration home position sensor
b. DC controller PCB (J304) <-> relay connector <-> horizontal registration motor
NO: Connect the connectors.
2. Sensor lever (damage and interference),
Sensor
Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation?
YES:
a. The horizontal registration assembly is out of place because of damage to the sensor lever. Replace the sensor lever.
b. The horizontal registration assembly malfunctions because of the presence of foreign matter. Remove the foreign matter.
c. The sensor is faulty and cannot detect home position. Replace the sensor.
3. Horizontal registration motor, DC controller PCB
Is the horizontal registration motor control signal generated by the DC controller PCB?
J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
YES: The horizontal registration motor is faulty.
Replace the motor.
NO: Replace the DC controller PCB.
and another error machine on my ir5000dx (E000602-0003) if you can help me and thx a lote
1. Connector
Sensor
YES:
Replace the motor.
NO: Replace the DC controller PCB.Leave a comment:
Guest repliedcopeur CANON IR3300 error E000051-0000
copeur CANON IR3300 error E000051-0000Leave a comment:
press additional functions release press 28 at same time release press additional functions again u should now see service mode if not press c/a key
start over
in service mode press copier function clear err ok then turn off on main power some error codes will cause copier to power of in 60 90 secs so be quickLeave a comment:
You can't find function in additional functions.Need to go in service mode.Leave a comment:
guest_started_a_topic_y_with_prefix
